  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey josh,
that avatar...what TV show was that from... It is scaring me in a deep seated psychological way that can only come from trauma caused by being forced to watch the show when I was a young child (damn you older siblings)
Nexus, Muppets :)
Yeah he's a muppet, but I don't think he was on "The Muppets" though, it was a different show and the co-host used to be able to zip his mouth up.... in fact I think his name had something to do with Zips (makes sense)
Cool.... so you are living the life of the idle rich ( without the rich part) :)
Were they shocked? Did they see it coming? Did they beg for you to stay?
hehe yeah I will need some work at some point.... bank accounts arent self replenishing....
Shocked: yes. See it coming: possiibly. Ask em to stay: yes.
sweet.. know the feeling -- was soooooo good for a while.. until I ran out of money :D Even just having the one working day off a week was nice to be able to do that, now don't even have that :D
yer, watch out smooth is going to go arnie on us all :)
Yeh his name is zippy. If he wasnt on the muppets show, im not sure then.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
