  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh i do...
I'm not sure if I'm spossed to pick Ben up or meet him there...
I've never met him and dont even know what he looks like...
omg.. that sounds like a blind date kinda thing...
Glenn u will have PM soon.
yeh i do...
Ben is 6.5 foot tall and weighs abt 200 pounds. you might need to rip out your front passenger seat for the night so as to give him enough room to stretch his legs..... and roll his body....
oh funny moment was driving down the road i was manualy shifting the auto then i went for the clutch with the left foot and hit the oversize brake pedal
my brain goes, oooooh we are in an auto, forgot about that
I do that neary every time I get into an auto....takes a couple of starts to get used to turning your brain off when you drive.....no offence Adrian :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
