  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeap, I am not that far off the highway as you are though, strutto knows where I am :( Then the hard decision, who is going to be driving the most interestingly :)
Yeah if you can convice everyone to stop in and pick me up I would appreciate it, if not then ke cera cera :)
