  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol.. that's fine... just make sure you dun ruin my reputation :)
and WAT special relation btw me and Jason?? i have special relationships with each and every single one of you :aroused:
my relationship with little Nicky's the BEST :ghost:
ruin your reputation..... can't see that happening
(interpret that as you will) :)
frkin :cuss: :) yeh well everything fun is out of the question this weekend.... especially when i got the saturday off :) no work and no car...... timing is always impeccable FAK
you still have that
poorly made korean car [unquote from adrian] haven you??
