  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mmmm midnight purple, it would have to be really dark
might see if i can dig up a replacement dash and sand it back and give it a go, my current one is borked anyway, its cracked in the spot over the steering wheel
Yeah mine has been in and out of the car so many times, it is starting to develop exactly the same crack :)
Yeh :)
I couldnt/wouldnt be bothered driving to nimbin. Especially not in the skyline.
Theyd take one look at me, the car and the japanese on the side and arrest me for intent to have sold drugs to buy the car lol
or something like that.
all i know is ide get searched every 5mins in my car
besides, i wouldnt trust parking my car there either, i dont trust most straight people, let alone drug fuc*ed hippies lol
im not a hypocrit, i smoke occasionally, and do other things now and then, but its a special occasion. not every 15mins :wassup:
i wann goto amsterdam for a holiday at the end of the year, that should be fun ;)
yer mine came in and out a heap with all the shit that i installed, but theres nothing to be installed in the dash anymore so i dont think it has to come out again
I hate taking all the dash surround out, it shits me, so fiddly and annoying
Plus the more your move/remove/insert etc things the looser and more rattly they get
i wann goto amsterdam for a holiday at the end of the year, that should be fun :)
I've been there... it is heaps of fun (from what I can remember anyway) ;)
But you would only go for a holiday.... living there would be the end of a lot of peoples productive lives IMHO
I wanna spray just the door console bits where the elec window buttons etc are
How hard is it get them off and spray?
Theres a rubber coating yeh? so i gotta sand it all down, do i really need a primer/undercoat
im going to do it silver
yeah gotta sand it back.... and you must use primer, or the paint bubbles and pools in certain areas. Takes a little longer but worth it in the end.
The door trim is probably the easiest stuff to pull out and is the best place to start.
Cool, thanks guys
mite give it a go this week
so i need to look for some plastic primer?, does the actuall paint have to be for plastic or it doesnt matter
ive got my back seats and parcel shelf out at the mo, trying to see if i can get 6x9s in there without any cutting etc, its looking like it mite just work
mite need to use spacers but should be ok.
I dont really want subs so i need some bass = 6x9s
Anyone know good cheap sound deadening material?
I was just gonna goto kmart and grab two of those foam strips u take camping and lay on the ground. I wanna put the on the bottom and back of the back seats to help get rid of some road noise
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
