Hey smooth, what size rims you running, I have a set of 17x8s with passable tread if you really wanted to come tomorrow.  I think the pattern is similar to yours too.
Im running the same sizes I believe.... Im just going to wait till my trye is good to go before heding out...
I appreciate the offer though Jason... your a true champion :)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
No worries mate. The offer stands if you change you mind. I am saving them for the next Q.R. or Morgan Park track day. hehe.
SCHOOLIES WAS MAD, were all sitting on our couch which we dragged out on the balcony maggot as all hell watching all the mad cars on the espy and out of the corner of my eye the couch from one of the top floor apartements next to us sales past and into the pool below followed by the kitchen table and many chairs!!!
haha, where were u staying?!
A commodore decided to show off and do donuts, he then hit the kerb and smacked into
a pole (or tree).
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
