  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
honey comb picnics are you insane NUTS YUKKIE!!!!!!!!!!!!!!!!!!!!!!! picnics never do i eat them. after the time i ate some peanuts with the shells still on :S yets say was not pretty for mum to clean up once it all up back up
there is honey comb bits instead of peanuts.....
thats why they are so damn good....
peanuts are :throwup:
no worries...I'll have to get IIS back up and running
btw I only have 256 upload, so it won't be all that quick....
Cool just PM me usernames passwords addresses and instructions, I have only dealt with linux boxen before, only really having a go at IIS now that we actually run it here onsite, man it is a royal pain in the ASS!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
