  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I thought they were pretty good.  I used my last set for 35 laps around Q.R. and they did pretty well.  Looked a little worse for wear afterwards though as to be expected under those conditions.  Great in the wet, and I beat Paul by 2 sec at the last time trial (forget witches hat).  Can't be too bad.
Don't how much they would be in your size Eugene.
i do agree but paul and i both had them on when we hit morgan park short track
and after 5 or more hard laps they started gettin greasy on me, and he complained of the same problem
I did encounter a bit of understeer after a couple of laps, the tyre isn't particularly suited to track work, I think the blocks are too big on the outside of the tyre. Having said that, you should never encounter that type of heat/punishment on the road unless you are a complete phsyco. I think they are a great tyre for road conditions, spirited drives through the mountains and the like. I will be getting them again.
mine would be cheap.. i really want to sell the whole rims and tyres as the lot.. i got em posted up on a couple of other forums. They're gts-x rims, but will fit an R33 n/a. But really if you just want tyres, go buy some tyres ;) 16" good tyres should be cheap.
i got them for the 31, but with the buggered diff its not doing anything like a burnout anytime soon. Prolly too underpowerd anyhow :D
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
