  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
id have no idea, but thinking out loud has often been mistaken for insanity
I usually direct all verbal conversation to the most intelligent person in the room, invariably it is me, ergo I do a lot of talking to myself :)
