  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hahahaha, i just gave up making the trim piece for tonight, ill try finish it off tomorrow and give it a didgy spray on thursday or something, cant be farked putting th tv or x box back into it either though about it and it was too much effort
