  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just saw one of the most trippy things….was at Subway on Fairfield Rd, gazing upon my car in the carpark (as you do :cheers: ) Driving past was what I’d like to call a clone of my car! A Dark Blue R34, same colour number plates etc etc….maybe a common occurance for the R32 & 33 guys…but it was weird seeing one VERY similar to my one on the same road that I frequent.
Anyway that’s my rambling over!
Yeah work supplied me with a sim card and i bummed an old phone from a freind, but aint got a charger or a battery, but apparently 5 cents a min for rates flat is good for mob phone and that is what I'll be getting with my work sim card, or somethin or other.......? I am not good with mob phones, but $20 for a battery and $30 for a charger, friggin ell !!!!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
