  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
fine blame me mate i couldnt care less...i didnt know how hosh drives
There is no need to blame... i was just confused as to how he got there...
THink of it this way, if your on a run when u get ur car, do u want some guy you dont know and no one really invited driving like a moron behind you? Im thinking no benji...
