  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well i think we even have beers in the fridge.. tempting.. i'd love to greet a customer with a beer in my hand, i think that would go down well.
squizz: what are you doing here? aren't you in rockhampton?
Leave tonight dudely...
you guys going for a longweekend or just the weekend?
i almost would'a come but was unsure about my car being back, etc.. now i have too much shit i need to do to it like put my interior back together.
my old man was in the car last night and he is going "whats this crap i am kicking near my feet".. i told him "don't worry, its just the ECU sitting on the floor if you kick it hard enough the car will just come to a complete stop while driving" :D
One word : W00t.
definitely.. was driving it this morning.. sunroof open.. sun shiney. listening to some RATM cranking on the stereo.. see its times like that having a cool car is nice.
they basically resprayed the whole side of the car.. now looking better than it ever did.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
