  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well i think we even have beers in the fridge.. tempting.. i'd love to greet a customer with a beer in my hand, i think that would go down well.
squizz: what are you doing here? aren't you in rockhampton?
Leave tonight dudely...
you guys going for a longweekend or just the weekend?
i almost would'a come but was unsure about my car being back, etc.. now i have too much shit i need to do to it like put my interior back together.
my old man was in the car last night and he is going "whats this crap i am kicking near my feet".. i told him "don't worry, its just the ECU sitting on the floor if you kick it hard enough the car will just come to a complete stop while driving" :D
One word : W00t.
definitely.. was driving it this morning.. sunroof open.. sun shiney. listening to some RATM cranking on the stereo.. see its times like that having a cool car is nice.
they basically resprayed the whole side of the car.. now looking better than it ever did.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
