  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah i was at aspley with a few mates hes got a green 1200 ute u mighta seen it, and his mate bought the ceffy and yeah they had a pit setup he got done for tint, zorst, windscreen washers and height, and also the car isnt in his name yet or some shit its still under the name of some lady....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
