  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
*Sigh's* Nope!
He was going off his nut at how much of a prick it was to find parts, and that he kept finding little things wrong, he was not a happy chappy, but he definately said by next Wednesday... I forget what my car looks like :D
I was reading your DIY thread the other day, seems pretty easy, I went and bought some spare hose clamps and was gunna give it a shot myself, but if MJ needs to as well, then yeah I'll wait for dodgey day.
hey shane.. i see you there.. lurking.. :)
how is your car going? do you have it back yet?
MJ also wants to do a fuel pump in a week or two.. so if u still want to do yours, we'll have another dodgy mechanic day somewhere
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
