  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
only thing that sorta raised my eyebrow was erin being told to shut up, shes a moderator, in that capacity, if she says something, it should be taken note of.
There is only one mod and one super mod that I will listen to. Basically whatever the super mod says goes. And he yells at me nearly every time I see him, and I see him every second day in person. Hence the complete lack of fighting from me today.
Negative... You WILL listen to all mods...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
