  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Im not even going to pretend like I get what your on about...
But...
Ahhh play well?? lol
Google GO boardgame. It's that game russel crowe was playing in "a beautiful mind" Then he lost and he chucked a tanti. The one with black and white peices that all look the same.
Hmmmm, not as exciting as kittens;
Go is an ancient abstract strategy game which is played on a wooden board consisting of a 19 x 19 matrix using black and white stones. It originated in China about 4,000 years ago where it was called Wei-Qi. It spread throughout the Orient and underwent further extensive developments in both Japan, where it is known as I-Go or simply Go (the name now universally applied), and Korea where it is known as Baduk.
Go theoretically takes place in the feudal age and has as its goal the surrounding of territory consisting of empty points on the board. The rules of the game are extremely simple, easily learned by children in fact, but the intricacies of gameplay can become extremely complex due to the virtually infinite possibilities. The subtle combination of intense concentration, abstract reasoning, and intuition, can take a lifetime to master.
Go is not exclusively an intellectual pursuit, however. It is also a grand aesthetic achievement. As one author so aptly stated, "The unfolding of geometrical patterns, the interaction of the basic elements of line and circle, stone and wood, and the meshing of grand-scale opposing strategies make go an artful game." It is this combinaiton of artistic and intellectual qualities which has captivated players of all ages and kept them in the pursuit of mastery for several millenia.
On that intellectual note, im out of here :P
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
