hey all.. well adrian is gonna go look at strippers the lucky bastard :(
hmm.. good news for me - today i found the RB30E i have in my old car is a s2 block - high compression turbo conversion is going ahead! lets see how long it will last! :)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
:) lots of costs and its sending me too backward, finding it really hard to save any money.
Its a great car, but i want to move onto some other things, and be debt free for a while.
Also i guess its not just not "right" for where i am now.. its a lot different to when i was in melb. Then I worked 20mins away, had a lockup garage, earned a fair bit more money, etc, etc.
Its going in for Gavin treatment on the 8th which should give it back its mojo and make me not scared to drive it, but i'm not going to rush to sell it. Hopefully that takes a couple of months so i can continue to enjoy it.
ok, i popped back before i do go out to the shops :)
hehe.. well 150rwkw should be fairly achieveable with most VL turbo bits and RB25DET turbo. Quite a few others have done it with good results, and most of it I should be able to DIY (its just bolting on stuff after all). So yeah, it could be fun (and importantly it will be cheap)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
