  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ive got the bigger petrol version, this is a little 1/18th scale one to go drifting with in my bedroom, i dont have nankangs, i have GT Radials front and G3 Potenza's rear (the potenza's are farken awesome tyres but are kinda bald) the GT's have tonnes of tread, 1600 bucks, there's not a mark on ne of them
