  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I'm soo ****ing sick of being asked every ****en weekend what night I'm having my birthday.
I wish they would ****en listen to me the first time.
Oh and my sister nicely changed what cake I am having to. I wish they'd just leave me alone. I reckon they are up to something and are trying to put me off.. But it's making me more suspicious.
