  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
they carded it for a business? lol .. thanks for picking it up too.
camgear is somewhere on a plane from japan to sydney.. its going to get here about 3 days late i think for gavin to put it on during timing belt, etc.. so i'm going to have MJ's camgear. When it does actually arrive, he has mine. All worked out :)
Well it worked out for you but not fo me :)
Oh my Chris you really have dropped off the pace somewhat, must mean you got a life, DAMN YOU!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
Hmmmmmmmm having Ben move in will mean I will be able to catch up to him, as I only have a work laptop which no one uses but me atm, as it has certain company info, so it is for my use only, meaning Benny boy will be without net access until I can get another computer organised :) looks like it is going to take a while!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
If you want to call her that :)
I never cared about post counts anyway, they mean absolutely nothing
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
I don't even get a mention! Damn me and my 6 months with no pc!
