  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
but all the hard work will go towards the line later this year sometime
yeah nothing like that feeling after you get some work done on your wheels & feel it push you into the back of the seat as you mash your foot into the go pedal :flamed: :burnout:
i would not mind working 9-5 at all
Well that is the hours we are open, but I have to be there half an hour before the others show up and I am usually there an hour after they are gone.
The pressures of being in charge :rant:
