  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Scoring:
12 correct answers: One hot brother!
9-11 correct: Call your fam and friends -- you're a metro!
6-8 correct: Keep it up, you have serious potential!
3-4 correct: Go buy the latest GQ and study up!
0-2 correct: You're a lost cause.
You answered 3 questions correctly out of a possible 12 questions
Oh dear.
Scoring:
Oh dear.
Lol every one so far, is so much more metro then me.
