  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Honey I'm home!
Hmmmmmm definatly putting the plumb back back on for my stocker BOV, GEEZE the stocker makes a HUGE PPPPSSSSHHHHHHTTTTT but car runs like CRAP!
Gotta wait for Benji to get home first going to get some pics of Beau Repairs dodgy mech day :(
Anyone know how much a new battery cost for my R33? the battery i have i have deadened that many times it does not hold any charge anymore, used to hold just enough for me to start it, but now gotta push start it everytime :(
And you think you can catch us James? BAHAhbHA hA H HA hA hA HHAAaaaa it's only cause you have no car and got nothin better to do, the only one to come close was Glenn, and he was within 10 post of beating me when he went soft!
