  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cyrus... Call ur nearest ABS store...
I negotiated them down to do mine for $645... But couldnt get it done today now :(
Brand new daiken exceedy HD clutch, all bearings, flywheel machining the lot :)
Cool well done, am going to wait for Gav to get back to me, Amanda is going to ring around and see what the best price they can do for me, see what they can do then call ABS :D
I bought James's old stock BOV for my GTST yesterday since he no longer requires it. I have never had a re-circ tyoe bov on the GTST in the 2.75 yrs of ownership, How much better does it run. Nice crisp return to idle when you come of throttle, no snap, crackle, pop between gears not to mention sounding completely different to drive. Might have to get my finger out to fit the stocker onto the GTR, much bigger job though. THANKS JAMES, if you ever log on today.
hay matty,
have been kind of busy this week.  I really shouldn't be whoring right now but I just can't help myself.  How's your week been?
Yeah i've actually been busy, had a few things come up which are pissing me off...
COuldnt get my clutch done today in the end and im going away on friday, so It will have to wait :P
im in a shitty mood lol
hey jason.  How did the ankle heal up in the end?   And how is the R running?
Ankle still sux, at least I can get around now without a drama, just can't move it out of its comforts zone otherwise it really lets me know, still doing physio twice a week. R is good touch wood, there seems to be alot going BANG! at the moment, kinda scary when I bought mine from an auction slip.
So the difference of a BOV change is that noticable? wow... you hear so many people say they are for show... glad they are wrong because I love my BOV :P
Yeah, but I was going back to a stock one though. I am pretty sure the atmo one on the car when I got it was a no frills version though, looks pretty budjet.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
