  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh yeh.... while ur hmmm might be bigger than mine, i might have other things bigger than u ;)
that sounds like a pepsi challenge Nick
I am ready with a tape measure at the next cruise.... if you are :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
