  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
In Tennnessee, a guy sees a sign in front of a house:
"Talking Dog for Sale."
He rings the bell and the owner tells him the dog is in the
backyard. The guy goes into the backyard and sees a black
mutt just sitting there.
"You talk?" he asks.
"Yep," the mutt replies.
"So, what's your story?"
The mutt looks up and says, "Well, I discovered my gift of
talking pretty young and I wanted to help the government,
so I told the CIA about my gift, and in no time they had me
jetting from country to country, sitting in rooms with spies
and world leaders, because no one figured a dog would be
eavesdropping. I was one of their most valuable spies for
eight years running. The jetting around really tired me out,
and I knew I wasn't getting any younger and I wanted to settle
down. So I signed up for a job at the airport to do some
undercover security work, mostly wandering near suspicious
characters and listening in. I uncovered some incredible
dealings there and was awarded a batch of medals. Had a wife,
a mess of puppies, and now I'm just retired."
The guy is amazed. He goes back in and asks the owner what
he wants for the dog.
The owner says, "Ten bucks."
The guy says, "This dog is amazing. Why on earth are you
selling him so cheap?"
The owner replies, "Aw, he's just a big liar. He didn't do
any of that shit."
No not yet James
Travelling salesman rings a doorbell. Door is opened by a boy, eight years
old, wearing a top hat and a tutu. He has a large martini in one hand, a
cigar in the other.
"Young man, are your parents at home?" asks the travelling salesman.
Replies the boy, "What the fark do _you_ think?"
Actually Luke it was a Protestant Priest :)
cigar in the other.
Replies the boy, "What the **** do _you_ think?"
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
