  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
where the red one connects to the plenum, there is another connection on the plenum a few centimetres under it
can someone do me a favour and go check theirs? i wana go for a drive and dont want nething going bang
just did.
red to the bottom angled one (carbon canister)
yellow to the top (bov)
bit sick of it.. costing me too much in non-performance related items.. bit worried about depreciation really kicking in soon.
i really want something with around 300rwkw+. I could do it to the R33, but think i'd prefer to start over with something else and everything i learned from the r33 i think.
im working very hard to build up mod money atm. had a small setback with the car going in on friday to have the cam belt re-done with the bearings this time. get em to do oil too. then ill do plugs just before the pfc tune. all should happen in the next 2 weeks with any luck.
shit.. so your idler bearings gave way?
mine gavin said "they look a bit worn.. best to change them" and i ummed a bit, but in the end just told him to do it.. probably not going to effect me, but next owner it could backfire on if they were left.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
