  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
maybe a chaser (or GTR really!) later on though.. i need some capital.
yeah.. the drag GTR are nutz.. i'd be happy with 12's to start. .. it'll just be the cost of the turbo to get any lower that will be prohibitive
Just turning the key in a GTR is expensive!!!!!!!!!!
A chaser would be the goods, seen a few nice examples in mags, have a more classy look with the serious hp potential.
yeah.. dey cool. .only prob i was thinking when i thought about it.. 1jz-gte parts are available and things.. but the other crap like bodykits and just accessories like suspension, etc = very rare in australia.. basically every little thing would have to come from jap.. which would be cool - but add up into expensive car over time. But hell it would be original and cool :)
2 more drawings to finish and i can call it a day, a very very long day. lol
MMMMM agreed, just finished doing a whole bunch of calcs for kerb offsets, sewer and stormwater lines. Just killing a bit of time while the brain unwinds. Then I have to get up at 6am and do it all again. Cool!!!!
Im back :)
All i can say is WOW!!
I did a highway run at .95bar and she pulls like a mother****er!
Perfect all the way to redline, no missing or problems at all.
Today i gapped my iridiums to about .7-8, they were 1.1mm, taped up the coil packs while i had them out, this really does work! And i also put catch can on :)
Thats adding to the trust ic and avcr i put on the other day hehe
Avcr is amazing, ive used them before, but never personally with my own car, the boost control is amazing, it holds whatever i set and holds it perfect.
Boost is stronger and faster down low and when changing gears on boost, there is 0 lag.
adrenelin is pumping :headspin:
Im back :)
nice!!
Thanks, first proper performance mods ive done to the car :)
Next is tyres, all 4 of them :)
Then its all uphill, Ces split dump+front, Hiflow, safc+sitc tuning etc
the it will haul
Just adding the recent stuff has brought a smile back to my face :aroused:
My dads gone overseas with the digital camera too :D otherwise ide have some nice photoshoots to show off the new equipment
the it will haul
yea i cant wait till i have some money to add cooler and highflow turbo etc into the equation
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
