  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly.. the car of course... The lil nagging problem I had wif the HICAS light and the rattling noises is become all too frequent and its damn annoying..
Just got a call from my mechanic, he's organising a data stream to see what exactly is wrong..  HICAS sensors apparently is not covered under my warranty.. but ABS is ... grrr.. not happy at all..
Hrmm.. guess the bright side is that a friend of mine is going to help me get some insulation into the doors and also fix the creaking that I have had on the passenger door for a while.
Whats wrong with your car dude? :D
Nexus.. I heard something about his wife taking over 75% of everything he owns and the shop was shut ?  I might have got it all wrong... thats why I wanted to see if you guys/grls know anything about it. :)
I THINK THAT MY PERSONAL LIFE HAS NOTHING TO DO WITH YOU OK
THE INFO YOU HAVE HEARD IS BULLSHIT.
SO SHUT YOUR MOUTH PLEASE - OR MY SOLICITOR MIGHT DO IT FOR YOU.
Yeah...  She may just come in here and set the story straight :headspin:
NO I WILL THANKYOU
GAVIN WOOD AUTO TECH IS NOT CLOSING DOWN AND NEVER WILL OK
I AM BUILDING THE BUSINESS TO GIVE TO MY 2 BOYS WHEN THEY GROW UP
THEY ARE ALREADY FOLLOWING DADS FOOTSTEPS WITH REGARD TO
MOTOR RACING
IF ANYONE HAS ANY QUERIES OR DOUBTS - PLEASE DONT HESITATE
TO CONTACT ME ON 0417760278
I WILL BE MORE THAN HAPPY TO SET THE STORY STRAIGHT
IT SEEMS TO ME THAT A LOT OF PEOPLE ON THIS SITE HAVE NOTHING BETTER
TO DO THAN BAG SOMEONE ELSES LIFE - THAT TO ME IS VERY SAD
GET A LIFE PEOPLE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GAVIN WOOD.
Not at work, the time over on the island was awesome, had a great time, but too much exercise for me, did more exercise in the last 3 days than I have in the last 3 years, so still a bit stiff and sore, got a raging head cold which is why I decided to call in sick :D
i think somebody wanted to set some rumours straight.. fair enough i guess..
Please PM WTF that was all about plz?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
