Any ideas on how to get around them?
Even on perfect CDs I get them.
Tried ripping at every available speed from 1.00X to 32.00X.
Tried EAC, Audiocatalyst, iTunes, even copying the WAV files with random programs then using Audiocatalyst to convert to mp3.
Tried several different encoders (including all bitrates between 128 and 320k)
Sorta running out of ideas... maybe the cdrom is just sh1t? Aopen 52x32x52...
where r u getting the tracks from because it will most likely be from the sorce & if so u are not going to get rid of em :Bang:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey mike.. waz up?
well now i sold my r33 i might do some stuff on the r31..
might come this weekend to see what i might buy off your wreck. at the moment the only thing that is really bothering me is the odometer stopping about a month ago.. but i just need the little bit inside the cluster. its hard to explain.
rest not sure. one minute some of the worn stuff bothers me, at others its just extra character :D
I got around them by creating an iso image of the cd using alcohol 120%, using isobuster to correct any "errors" Using Daemon tools to run the corrected iso image then using Musicmatch Jukebox to rip them.
Pain in the arse but it worked for me
probably :D is the pops playing on every device u try and play it back on?
i never have had probs? i was using a pioneer drive to rip them though?
oh them..
from what i remember i think i just used nero to extract each track as WAV's.. then fed thru musicmatch to generate the mp3 ... worked fine using the pioneer. I think some drives must just be more sensitive to the protection than others?
i think it was how i did it on a couple of cds anyhow.. but i forget. they could have brought out even newer protection.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
