  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
General Info
Price:$800,000
Miles Per Gallon:--- mpg
Curb Weight:--- lbs
Layout:Mid-Engine/AWD
Transmission:7-Speed Sequential
EngineType:Quad-Turbo W16
Displacement:7993 cc
Horsepower:1001 bhp @ 6000 rpm
Torque:922 lb-ft @ 3500 rpm
Redline:--- rpm
Performance
0-60 mph:3 sec
0-100 mph:--- sec
Quarter Mile:--- sec @ 112 mph
Skidpad:---
Top Speed:252 mph
Braking, 60-0 mph:--- ft
Slalom Speed:--- mph
10% deposit?!
Wholley crap!
I'm thinking of booking the dyno day for the 14th August which is a Saturday, anyone have any objections?
It's just, this weekend is the sprints, the weekend after probably isn't enough notice, the weekend after is my birthday (heh.. priorities!!) then the weekend after that is the sau launch .. then the 14th is the weekend after that! So yeah.
Anyone got any objections?
I've rung/contacted Dynosource 4 times now and they haven't got back to me. SO I've kinda given up on that idea.
Unless someone can get a price out of them, but the customer service is very lacking just to get a quote, so what owuld it be like on the actual day?
from the rear looks like a ferrari is backing one up...
yes! I don't have a car anymore :cheers: . .but meh.. i may come to watch all the fast cars *sniff*
yeah, if they aren't getting back to you probably means they're not too keen on the dyno day .. I guess for them its a bit of a hassle opening the workshop on the weekend, having somebody around - and in the end they probably don't make too much money (if any)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
