  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
the t610 screen was crap
the new one has 16 Bit colour, other than that it is the same as the T610
After being Data admin for a phone company and seeing firsthand how dodgy they all really are, it is hard for me to get excited about a phone :?
