  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
My videos:
Belgarion hooning. The damn car was so loud it scared the sh*t out of the kid next to us:
http://www.boostcruising.com/members/krawl...-_Belgarion.mpg (1.6mb)
The black supra that sounds so goddamn horny:
http://www.boostcruising.com/members/krawl...Black_Supra.mpg[/color] (1.23mb)
MELVs GTR racing PRO-300 VL down the main straight:
http://www.boostcruising.com/members/krawl...-_GTR_VS_VL.mpg[/color] (2.99mb)
MELVs GTR finishing his lap to the commentary of Random Kid:
http://www.boostcruising.com/members/krawl..._-_MELV_GTR.mpg[/color] (2.98mb)
The porsche flying down the main straight. Doesnt sound nearly as tough as an RB:
http://www.boostcruising.com/members/krawl...t_-_Porsche.mpg[/color] (1.11mb)
Neil (Team Krazy) and his amazing Flaming Skyline ... These sorts of flames were constant, with a few bigger ones on occasion. Pity I missed the big ones :P
http://www.boostcruising.com/members/krawl...-_TeamKrazy.mpg[/color] (0.98mb)
