  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Tax day today , hoping to get between $650-$900 , will pay for Dyno Day + tune and mods fitted by Gavin before the Skid pan day , still need to get piping done . Can anyone help/ recomend someone ? and no Warick I am not doing it myself .
