  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
q3 is yawn.. ut is better..
counterstrike... yeah, i got that with the card actually.. never really got into it, but i am still lacking broadband so mainly single player for me.
yes i am bandwidth p00r .. and still paying $70 a month for the privelege.. how shitty is that
lol..... yeh yeh... so when are u going to fight me in Q3 arena or even better yet... pick ur game and i'll challenge u gordo :)
I challenge you to a Connect 4 Championship! :rofl: I spent the better part of 4 years perfecting my Connect 4 skillz!
true.... yeh i used to be a bit of a pro-gamer but over that.... yeh i'm up for a UT challenge anytime.
Charly: nah my licence thing is definitley sorted. Hence why im still driving. Its all good mate just been neglecting my car a little. Needs a wash and some 100K service style TLC.
connect4 rox.. we used to play at my old work.. its quite an art..
lol - do you even *have* a license nick? :rofl:
bandwidth heaven :) oh how sweet.. bring it on!! but i must wait :rofl:
i think when i have off dialup i will ceremoniously burn my dialup modem - its put me through pain for the last year and soon it must die
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
