For those who are interested.... events/games are:
Counter strike (team based)
FIFA 2004
NFS Underground (circut 3 laps and best of 3 matches)
StarCraft (1v1)
Warcraft 3 (1v1)
Halo (x-box capture the flag style)
some other games as well but im not sure. I'll be playing starcraft, war 3, underground and fifa.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
then in canada some dude got bashed to death cos he was too good...
yeah.. i get that all the time.. i'm always having to fight people off .
Just this other day this guy came up to me and said
"YOU'RE JUST TOO GOOD I WANT TO KILL YOU!!!"
and i said "oh yeah?! just try it!!"
violence ensued but i thankfully beat him down in the end.
Its kind of annoying.
i got a black atx case, gigabyte motherboard.. 1.1ghz duron cpu, 468meg of memory, samsung 52x cd drive, 20gig HDD, Hercules 9000pro w/ 128meg, sblaster card, 10/100 network card.. all yours for the fine price of $350.
will run xp fine, and most games.. got a spare keyboard and logitech mouse if u want that as well.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
