  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hahah dodgy mechanic ska with extra dodgy :cheers:.... hey charly.... thought you'd be entertained by the stupidity of your work colleagues ;).... so is your car ready charly
what are you talking about nick? I've had my car back for about 2 weeks. Work colleagues..... um no. Not entertaining. SOmething is in the water everyone is grumpy as all hell. Probably the "winter blues" Fcuk people in brisbane are soft. If they hadn't seen the sky for over three weeks, the roads hadn't dried up in over 2 months, the temperature had been below zero for a the last month, and they only got 2 hours of partial sunlight a day I would be able to understand it.
13 degrees overnight is not Fcuking cold. 10 hours of sunlight and clear skies pretty much every day is not a bad deal. Want to feel miserable? Go live in a box with no windows in Europe for autmn and winter and you'll have something to complain about. Can they walk? yes, are they dying? no. should they all probably shut the fcuk up? yes. Should I be ranting? probably not. Why am I ranting? Because I hate the world and the total lack of justice. I would hate the world summer or winter. This place is just so screwed.
Just thought I'd share some of the love today. Hope everyone is having a good day.
Learn to use ****ing cliff notes.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
