things to do:
1. Tyres
2. Exhaust
3. Sway bars
it should be:
1. tyres
2. get it properly tuned and looked @ by someone professional.
3. go to CES to get your dump pipe install (when you get it) and exhaust looked @
4. Front Sway Bar (27mm front)
5. Rear Sway Bar (22 - 24mm adjusttable)
4 & 5 at the same time if you can.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh probably right glenn, just this car is exactly what im after now just too bad its in victoria.
you like it becos it looks good with the kit :rant:
there's always plenty of good looking skylines around here in Brisbane.
what bout this
NISSAN SKYLINE R33 1995 SERIES 2 GTST 5 Speed Manual, Electric Windows, Airconditioned, Power Steering, Central Locking, Full Body Kit, 3inch Exhaust, Turbo Timer, Blowoff Valve, Boost Control, Boost Gauge, Sports Gear Knob and Steering Wheel, 109,000 klms, Registered, Fully Serviced, GOOD CONDITION -$16500 Highland Park (0421) 353 112.
what bout this
yeah.. can check that out... but price is low though....might wanna take a good careful look @ it.
Guest
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
