  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
a name usually represent what an organization is about, and team shitbox has low representation at first glance doesnt it. i try not to assume anything, but calling a club team shitbox brings some things to mind straight away if you get my drift.
anyway, im not whining about this anymore,.
yeah.. i'm a little sick of it too.. for farksake.. who cares ABOUT ANYTHING .. when life comes down to it all you all end up dead.. so worrying about well anything, is well.. pointless.
my happy thought for the day :rofl:
squizz: you are cheese..
If this is the case then im going to warn A current affair for constantly having a go at the property industry *I* have worked in and around real esate for years...
guess you are used to being abused :rofl:
hey speaking of property.. my brother and his g/f bought a nice place over the weekend.. bastard ! then again he doesn't have a car obsession.
Christ, if I got upset everytime someone laughed at "Garage Spank" (www.garagespank.com) I'd never get around to selling any parts at more than reasonable prices with friendly service and beer surcharge for fitting...
*see above for unashamed self-promotion and shameless plug*
Guest
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
