  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah, it looks bad without any at all.. especially seeing as it has some mounting holes or something behind them :)
they were getting to the stage where they needed painting anyhow, but maybe they'll do for a bit.. can always sell them .. again!
Heya,
just finished putting greddy catch can on :)
can someone tell me where the small hose that comes off the factory BOV goes?
The higher or lower connection on the plenum?
It connects to the plenum, but i got them mixed up, there is 2 connections, both are an inch apart, one is supposed to connect to that carbon canister at the front of the car and one to the BOV
At the moment i have it going from the bov to the bottom connection
knore: you got it right.. lower.
the exhaust in my little pic there is HKS Super Dragger II .. i'd say its probably the only exhaust i'd want on my r33 after seeing/hearing quite a few but you probably don't want to know that.
now you got me weirded out Michizane ..
i think the stock BOV is meant to go *above* that to near the top of the plenum.. the carbon canister one i'm not sure where the hell you have that going?? but i think that is too low.
Guest
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
