  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
You running your own business now pred?
Basically from now on I am a web contractor.. which means for the most part I will be working from home. Today was my last day at umart, as now I have a contract for a couple of months for a development job, then after that some solid work. But I work from home, and just invoice people for work I do for them..
LOL pred is that a business expense
It could now be! many things can now be a legitimate business expense... internet costs, phone bills, electricity.. Have to speak to an accountant, or the mafia, one or the other..
Photos - Willowbank Nov 17th - 99AMS
G'day Angus,
Just wondering if you have any pics of my car from the above night...
Silver 33 Skyline Sedan (4 door) with a stupidly large wing on the boot... Plates 99AMS...
I saw you snap maybe one or two but wasn't really paying much attention...
I only want them for personal posterity reasons, and digital copies are fine, but if you require payment for these, let me know the damage...
Thanks in advance...
Adrian...
Your not thinking outside of the square... Your business is at home... You wear clothes at home... Clothes = Business Expense...
This formula can be applied to most anything...
But don't see an accountant, he will only try and confuse the issue...
yes, you are thinking like i am thinking ;)
"liquid beverage refreshments" = beer..
"office entertainment package" = stripper..
etc :)
Last time i spoke to accountant (few years ago) he wanted nothing of my shady suggestions! I mean I was most disappointed and appauled by his behaviour!
Visual stimulus for client waiting room...
Your thinking colour TV right?
Negative - Soundproof Media Room with projector, Bose surround sound including Subs under the floor, theatre chairs, popcorn machine, etc...
Perfectly legit... in a roundabout sort of a way...
oooo! new toy.. looks fun.. you going to do a 1/4 mile in it? :)
indeed... I think the new "company vehicle" may in fact require a larger turbo, for those bulky "clients" I am seeing and taking around all the time... just to give it that extra kick of power to carry the extra weight..
Guest
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
