  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Okay here is mine
the quote is from Bladerunner from a Nexus6 Replicant.
In the book "Do androids dream of electric sheep" on which Bladerunner was based the Nexus6 replicant was superceded by the Nexus9 replicant which was perfect in everyway, in fact it was "more Human than Human" (also a White Zombie song based on Bladerunner) there is no mention of the Nexus9 replicant in Bladerunner, only in the book.
That is reason number one
The other reason for the name is that the known universe is mapped in a 3 dimensional grid with each meeting point along the grid called a Nexus. Scientists have named I think 36 different Nexus points along this three dimensional grid. The centre of the universe is commonly known as Nexus #9
Therefore Nexus9 is the center of the universe and I am the Nexus9 :rofl:
L24e.......vane type afm...i know that SAFC's work with these meters but dint know if it would enable me to mod the motor as the stock ecu is not tunable.....at all
Bad-ass big....
I think the WOT stuff could be sorted with the SAFC... Not perfect but close enough... You can go +/- 50% all through the rev range...
I'd be a bit worried about the idle and cruise though with a big cam... Same amount of adjustment, but I'm not sure how the SAFC would handle the varying airflow at idle...
Couldn't hurt to try though... FWIW, the SAFCII would probably do a better job due to extra mapping points... But why not just get an older Microtech? About the same price as a SAFC these days...
Guest
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
