  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I met up with Cyrus and Jaqule and travelled as far as BP Yatala with them.
I think I managed to make a speed camera go off, but I was right next to a 4WD at the time so it will be too close for them and Cyrus was only a car length behind me in the other lane, so not too worried
other than that Ska's car is very slow :(
lol I wil sell it to you for $1090.... thats a $5 saving over buying one yourself :(
You still keen?
WTF I am doing this as a favour for you
I don't want your cheap imitation Carbon Fibre bonnet, I just don't want to see get in trouble Matt
I would expect at least a $10 discount :D
i wasnt serious about the contact :(
theres a place in brissy that does awesome looking fake carbon fibre but its not cheap $$$$
heres a pic http://www.modicoat.com/id46.htm
You cant tell its fake, the fibres look different to that...
I was studying mine the other day... It looks different fron different angles...
YAY CARBON FIBRE!!
as I have stated a number of times on this forum........derrrrrr....I'm not too bright....
I was just informed that MSCII starts at ~7PM....not 7AM......In which case......I CAN COME.... :headbang: Yessssss!!!
Guest
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
