Anyone in Sydney had a Cobb access port upgrade. If so please give us a run down on the benefits and gains. Any downsides (other than the obvious warranty thingo) and who installed it for you and for how much? Also, did you need to upgrade anything else (i think a midpipe is strongly recommended). That about covers it I think. If there is no one in Sydney I would also value anyone elses oppinion on it.
https://www.sau.com.au/forums/topic/343236-cobb-access-port-upgrade/
I'm in Sydney and have the Cobb AP - with three Willall tunes. E85, E85 drag and 98 tunes - provided by Martin. About 385awkw. It really is as good as per the thousands of posts and threads the world over. I think i ran a 11.1 @ 128mph on the 98 tune and 10.7 @ 132mph on the E85 tune (full weight) at WSID so compare these times to stocker numbers and you can see the benefits are pretty clear. Can't think of a downside really! For E85 you will need upgraded injectors and fuel pumps.
The COBB is the 'must have' mod.
with the new version including TCM support you would be mad to look at anything else.
many people have run either mail order tunes or custom tunes with impressive gains reliably on both the street and track.
do it!
Well i bit the bullet last Friday. The blokes at CRD did a great job.
Wow what a difference. The most noticeable thing so far is the mid range torque increase. No matter what speed or what gear, when you drop the foot it just pulls like a bastard.
  • 5 months later...
  • 1 year later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
