Hey all,
Does my series 1 r33 have a cabin air filter? if so where do i find this and how do I replace it??
Cheers
yes, all cars have cabin filter, in the 32 and 34 its in the aircon unit behind glove box, call nissan, changing it is a simple case of unclick panel remove filter insert new filter replace panel
https://www.sau.com.au/forums/topic/343258-cabin-airfilter/#findComment-5537628
i am also rather interested in knowing if there is a removable filter in the R33s.
in the past when i have taken out glove box and surround, i have never found what would appear to be a removable filter of sorts... maybe i'm just not looking in the right places.
surely someone would know, or someone with with their dash removed has seen it.
https://www.sau.com.au/forums/topic/343258-cabin-airfilter/#findComment-5538972
I thought I had seen a thread somewhere on this before for an R33 but I think it was the one for the Stagea I was thinking of which had photos.. thread here.
The below was taken form this thread...
1. remove glove box. There are 2 sliding clips at the bottom of the box (stick head into the foot well to see them), you slide them and pull them out, that will let you take the glove box out. There is a retracting cable that is attached to the right hand side of the glove box, that needs to be slid off to let you remove the whole box.
2. remove all the screws behind the glove box, including the clip that the box grabs to in order to stay shut. Can't remember how many, probably 4 or so. This lets you take the whole panel off and reveals the aircon blower and filters.
3. locate the rectangle white plastic thing. there is a metal clip on the bottom, take that off. then slide the whole plastic thing up and that allows you to take if off.
4. now the white plastic rectangle thing is off, the filters are revealed.
Might have to give this a look myself to see what condition they're in.. maybe clean or replace them.
https://www.sau.com.au/forums/topic/343258-cabin-airfilter/#findComment-5557791
  • 4 years later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
