hey
not really looking at big power
aiming for 200rwkw
on a r33 rb25det
atm got a fmic
full 3 inch exhaust (no high flow cat due to previous epa)
everything else is standard
was planning on boosting the as it is to around 12 psi and though id come pretty close to acheiving what i wanted
though have been warned by a few people not to on a standard r33 turbo
due to the ceramic wheel
and have been told if wanting a cheap upgrade
to get a r34 turbo or a vg30 turbo
is this right?
and if so what is a vg30 turbo?
im guessing these are standard turbos used on vg30det hence z31 300zx (all i know that is single turbo), would this be an upgrade as it is, and would this straight bolt on a rb25det?
same with the r34 turbo
thanks
https://www.sau.com.au/forums/topic/343351-turbo-upgrades/
Only reason to go the r34 turbo is if your highflowing realistically otherwise it's too much cost for too little gain. Even for highflowing i would just do it to the turbo you have.
But as Nismoid said you will get 200rwkw out of the turbo safely
https://www.sau.com.au/forums/topic/343351-turbo-upgrades/#findComment-5536414
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
