Hey people,
After upgrading the setup again, I have decided to let go of this magnificent combo. It has travelled 8,000k's and has aside from one broken rocker arm from a missed shift at the strip, it has never missed a beat.
Most people know the car, many of you have seen it perform. I have run a 9.6 second pass @ 144 mph on radials in the S13 on 609hp, since then it has made 651hp (486kW) at the wheels and run 148.98mph through the traps. That means it has the potential to run a low 9 in a full weight street car and drive home from the track like nothing happened. Despite the level of mods, it putts around like a normal SR with cams, doesn't get hot, doesn't chew oil, starts every morning and absolutely punishes just about anything that comes near it.
This is the heart of the fastest 4 cylinder in the country on radials, without the use of nitrous.
Not for an inexperienced driver, I cannot stress that enough!
I will give the purchaser a full spec list, but will give you a basic list. Please don't pick my brain for the finer details, as it took R & D to get this right. Built by Advance Motor Mechanics in Strathfield at a cost of double the asking price.
It includes:
Tomei pistons 20thou over
Tomei Rods
HKS Cams, valve springs
Tomei head gasket
Ported and polished head
ACL Race bearings
Nitrided crank
Precision billet turbocharger (less than 500km's old)
6Boost Twin scroll manifold
Twin Tial external wastegates and screamer pipes
Bored out GReddy plenum
Plazmaman 72mm throttle body customised to fit plenum
Sard fuel rail
Bosch ID2000 injectors
Trust baffled, extended sump
Tuned by JEM on E85
Performance: 485kW on 39psi (E85) Makes 20psi @ 4500 and 280kW
The engine is among the most lively available, also have a smaller exhaust housing which would bring the powerband 500rpm lower and make it mega zippy for those who are lag conscious. This is an 8 second setup in a lighter car and it will do it all day.
If you're considering building something big, save yourself a fortune and the guesswork with this proven combo, I can guarantee you there is no faster street SR than this in the country.
Obviously there is more to mention, if you are seriously interested give me a call on 0430 767 845. Serious enquiries only please, I did advertise it last year and had plenty of dreamers (understandably)
Can be seen on this link 15 second in
To be featured in upcoming Motive DVD Drag Challenge (March 2011)
NO EXPENSE SPARED, ONLY THE BEST OF THE BEST PARTS FROM JAPAN AND THE USA!
Cheers,
PJ
https://www.sau.com.au/forums/topic/343711-750hp-sr20det-street-race-engine/
Cannot speak highly enough of this freak of an SR. Without doubt the toughest in the country!
The cost of R&D alone to get this combo to where it is today is more WAY more than the asking price.
And is certainly a serious bit of gear :)
15k is a bargain, good luck with the sale Paul.
Hey people,
It includes:
Tomei Rods
Tomei head gasket
ACL Race bearings
Nitrided crank
Sard fuel rail
Tuned by JEM on E85
Cheers,
PJ
FREE BUMP FOR A TUFF ENGINE.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
