So 250k for the build alone, that is one expensive 34!
How does it compare to the R35 (though being that costly and all I doubt you'd actually race it, right?)?
Very very nice, I hope it is kept around for the next generation to see and appreciate as a classic 20th century car ;)
I just had a look at the pictures on the SpeedHunters website, and looking at the colour in good light I'd have to say it is virtually identical to the Porsche Atlas Grey colour that first appeared on the Careera GT's, and has since been available on every 911 since the 997's.
http://speedhunters.com/archive/2009/08/27/car-feature-gt-gt-top-secret-competizione-r-the-rebirth.aspx
http://www.6speedonline.com/forums/gt3-gt2-gt/204560-any-other-atlas-grey-997-2-gt3-out-there.html
Beautiful colour, though hard to keep clean.
  • 4 weeks later...
  • 4 weeks later...
Now, this is the car that originally inspired me to develop my own GTR.
Matty, what a delightful purchase you have made!
The only thing is you get to enjoy the end product only and not the joy in actually putting it together yourself.
hi matt, i will just enjoy it when the weather improves
i dont have 20mYen plus to spend on mods lol im afraid...
interior pics
